The OEM rear number plate insert to my origional rear bumper does not fit into the Impul bodykit. It is to wide.
The IMPUL bodykit takes a narrower Licence plate than the standard Australian Plate.
The easy fix is to simply fit the rear number plate into the bodykit without the number plate insert.
However the kit looks unfinished, as there is an indent at the rear of the bodykit which I origionally thought was for an uplight.
I assume the Japanese vehicles have narrower number plates than here in Australia.
If so, I will have to order a "Japanese" rear number plate insert.
It is probably going to be easier for me to order one from the US.
Could a US NICO member be so kind as to measure for me the inside measurements of the rear mumber plate and let me know the measurements.
This should be slightly wider than the actual number plate.
Thanks
AGM
