Ok guys so my 94 is at 211,xxx miles now. So the time has come for the 120k timing belt service, got the kit from Z1 motorsports, at the same time purchased a 4 piece underdrive pulley set because my crankshaft pulley was beat up. I finally broke it down replaced oil seals on cams and crankshaft. replaced belt, the first time the cams were all off by 2 or 3 teeth so I took apart and put it back together correctly and it still wont start. I've changed CAS and tested TPS, took line off fuel filter to make sure its flowing, took spark plug out of cylinder one and rotated motor to make sure I'm getting pressure, grounded spark plug to make sure I'm getting spark to ensure PTU was working correctly. It still isn't starting, so I'm f****** stumped
I need some help guys
