IM READY TO BUY MY 1ST MODS
DarkAges
Car: 2006 G35x
HELLO FELLOW G OWNERS. JUST WANTED SOME OPINIONS ON MY MOD CHOICES FOR MY 06 G35X SEDAN
1k budget
* HR style y-pipe. possibly megan racing brand. will this bolt on to my stock setup? $200
* Stillen z-tube $65
* Motordyne plenum spacer thermal copper 5/16 $200
* HKS sports dual tip muffler. part# 32008-bn001 $500. with the correct brackets will this bolt on to stock pipes behind stock cats?
* muffler brackets and hangers $50
inf 08146-8252g x2
inf 20651-af400 x2
inf 20742-af400
a mechanic told me some of these mods could cause the check engine light to stay on. any truth to this?
thanks for the time!
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
best bang for buck is the 5/16 plenum spacer combined with the z-tube... usable mid range power and better engine sound. had these installed on my 2005 g35x, didnt get any check engine lights and i installed it my self. Just have to make sure you use a torque wrench and screw bolts on the spacer in the prescribed pattern... like 18 bolts. Its a very easy mod, but not one to be rushed...
As far as exhaust, i just had a 2005-2006 coupe mid pipe installed, with stock muffler. But i havent heard anything bad about megan racing or HKS axle backs, even seen people mix and match them.
FlyG35
Car: 2003 Infiniti G35 Coupe
I have the 5/16 Plenum spacer installed from the previous owner, what I'm curious about is what is the actual gain of this mod? Or does it simply add to the throaty sound of the engine?
pae9132
Car: Modified 03 V35
you can find it at motordyneengineering.com
kmckis1029
since you brought the car with it... you wont "feel" the gains... but i can assure you your car is different without the spacer.
DarkAges
Car: 2006 G35x
i have been doing some research lately for my next mods in the near future. would appreciate any input on these, thanks! 06 g35x auto
- transgo valve body kit upgrade
- unorthodox crank pulley with belts
- stillen engine damper? also tower bar wont fit over my stock air box? idk...
- hotchkis sway bar. any good settings for this during install?
- berk hfc's
- need input on tire and rim size for my awd.
joe603
Car: 2014 Durango R/T
HFC's will have decent gains, as will a CAT-Back exhaust. I would stay away from underdrive pulleys. The engine damper will help when you have some serious power...supercharger/turbo/internal engine mods.
Shift kits will help times, but really not needed without extra HP.
The sway bar will be good if you track car.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Plenum spacer +1
Shift Kit +1
HFC +1
suspension mods are nice. Check the Fabricators market (fabricators-market.html) and there are a few things. Also check marketplace from time to time you can find deals.
DarkAges
Car: 2006 G35x
about the pulleys... as long as the new pulley is stock diameter it wouldnt be underdrive would it? the one im lookin at is just a little lighter
joe603
Should be fine then...I just don't like underdrive pulleys because I have stereo stuff...
audtatious
You can do lightened pulleys which are the same diameter. I know some have had issues with them allowing too much vibration and hurting the motor?
DarkAges
Car: 2006 G35x
im thinking about testing this combination on an old rim. plastidip white base, then white duplicolor engine enamel, then clear coat(not sure about a brand on this one) i understand im a little late getting started. i know the plastidip craze was a couple years ago. just curious if anyone has tried that combination.
also, for other parts of the car, say the grill or parts that get hit by bugs, would plastidip alone be ok? no other coating needed?
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
I have done the Unorthodox pulley on 2 VQ engines. If I had to do it over again I would not. It is just not worth it in my opinion. Negligible gains.
