Update: New cap and rotor. First tested spark from coil. Good. Tested spark to each plug using its wire. Good. Fuel always wetting my plugs. Good. Now I lifted off the valve cover rotated crank to 20 degrees BTDC, had distributor point to plug one. ?'s:
Both cam lobes were pointing away from engine, is this TDC for COMPRESSION stroke? I turn her over and still no start, I HATE IGNITION TIMING! Can someone please tell me what I'm still doing wrong? :help :help :help :help :help
I'm just so frustrated, I want to drive my fawking car ...
I appreciate your help fellas/gals ....
