odpl_DanW »
https://forums.nicoclub.com/odpl-danw-u110491.html
Wed Dec 31, 1969 5:00 pm
Hey buddy,
Its a 77 Late(EI)CA Deluxe king cab, w/remote module . So far,, advice here and elsewhere is use aftermarket self contained dist $79.99 which I will do.
Seems to be some confusion about dual point, dual cond dist. It doesnt work per normal dual poinT WHERE 1 set breaks and the other set makes contact
It runs on 1st set (10 BTDC) most of the time. Runs on second set(0 BTDC) ONLY WHEN IN THIRD GEAR (third gear detect sw screws into trans case like bu light sw), and WITH THROTTLE IN NORMAL CITY SPEED RANGE (20-40)mph (micro sw on throttle linkage)
You notice the performance hit when you shift to third, which goes away when you mash the gas. To reduce polution cruise in third. passing gear (full power) is always avail at your right foot.
Later
