ignition circuit relay isuuse
alright2020
Car: 92 jeep wrangler with SBC
99 F250 with 7.3 on 25lbs
91 300ZX na>tt>na
03 G35 coupe
ecu reads code 21..... i just put the motor and wiring harness back in.... the white connector to the ecu had all of the wires out of it and i had to put them all back in it... i matched them all with the ones of the harness it plugs in to... what else causes an ignition circuit issue? is there any way to figure out exactly which wires go where? there are two yellow wires with green stripes... idk?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you checked the ptu? thats generally what triggers the code 21
why was the harness depinned? there is no reason to depin the harness unless some bonehead tried running a crappy piggyback system
alright2020
91 300ZX na>tt>na
03 G35 coupe
de pinned to go through the firewall easier i guess... it was the ptu... i was kinda runnign on cruise control from lack of sleep and couldnt figure it out and just gave up for the night... first thing i did is check to see if anyone replied.. noone did then i looked at my ptu and it was unplugged on one side lol
