idle adjustment
mrmurphz
Car: 2007 Maxima SE
I recently cleaned out the tb on my 91 240sx and my idle went up afterward. I searched the thread for the correct way to adjust the idle but I couldn't find anything that could help me. I found the idle adjustment screw on the back of the intake manifold, but I couldn't find the tps sensor harness. I read that it should be disconnected before adjusting the idle. Can someone help me out or maybe describe where and what the tps sensor harness looks like? Thanks.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
The TPS connector is right above the throttle body. I believe there are two plugs. Just unplug the smaller one I believe. Someone correct me if Im wrong.
