1999 I-30
In OHM testing the IACV, following FSM section EC page 374, the current OHM readings are 40 as opposed to FSM spec at 30. I tested the good working 95 Maxima to get a baseline. The 95 Maxima readings are 29.8 to 30.
Just to verify, will a failing IACV have a higher OHM reading like 40?
I picked up another IACV from a 99 Maxima (pick-n-pull) along with the ECM and TCM to have as a spare. Both IACV units from the 99 models read 40 OHMs.
