I30 Noise Brakes or Bearings
JSullivan
Car: 1999 Infiniti
Starting getting this noise this past weekend. Checked the brake pads/rotors and they look ok. But it sounds like the brakes - it can be a constant sound or sometimes it will come and go. When I make a right turn it goes away as well. Thoughts would be appreciated. (Sorry about the wind noise it was an extremely windy day). Car seems to run fine otherwise....just annoying as I can't figure this out. Thanks
1999 I30 (140000)
[youtube]http://www.youtube.com/watch?v=yF2FIPIGGRo[/youtube]
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Based on symptoms, most likely a bad bearing on the left side. To confirm, jack up the suspected side, then grab the tire at 12 and 6 o' clock positions and try to rock it back and forth. If there is so much play, bad bearing.
rlimI30
Car: 2001 Infiniti I30 4 Door Sedan (KR4 Titanium).
I have 2001 Infiniti I30 and I recently had that sort same sound to my car as well. I put my car on jack stands and checked the brakes and replaced them due to looking a little thin. I also checked for any signs of leaking of grease from my cv boots and checked for any wear from any of my suspension. Bingo! I had a bad wheel bearing going out. I replaced that and it solved the issue however; apon my investigation I did notice that I will be needing a lower control arm in the near future.
OwnerCS
I had a bad bearing on the driver side on my I30 that I replaced today.. Actually I replaced both sides at the same time.
I pulled the hub then purchased a new bearings with inner and outer seals. I took the hubs to a local NAPA machine shop where they removed the old and pressed in a new bearing.
rlimI30
Owner CS...
I'm glad that u got that taken care of and isn't it nice to feel that u can drive anywhere and not feel embarressed about the noise coming from the car. LOl
Good Deal...
Ray
