labcoatmonkey »
https://forums.nicoclub.com/labcoatmonkey-u101139.html
Wed Jan 20, 2010 10:19 pm
Sorry i forgot to mention, the idle control valve seems to check out fine, i doublechecked every connection. Coils are all firing, injectors are good. If unmetered air was to be getting in wouldnt the car just stall or idle very low? Im going to pressurize the intake tomorrow and see if there might be a leak somewere. I took it to two different mechanics who "specialize" in nissan, 240sx etc. and one said its my CAS and I need to adjust my valves . So i took it to another mechanic and he said I should change the idle valve and adjust the screw, which i did a million times, yet the problem persists. Its getting to the point were I want to crack my scull against the motor. . Anyone ever have an issue with the VTC causing an irratic idle at operating temp?
