I replaced the oil pump on my car which requires removing the timing belt of course, and well now that I try to fire it up the engine takes awhile and is really hard to start almost to the point of it won't start, but I got it to start and it sounded and idled so rough, loud and erratic. It wouldn't stay running unless I gave it gas either. Car ran fine before doing any of this so I know it's not a fuel or any other issue really. Cause I've only touched a few things
Well Guess it's time to count the teeth between the marks on the timing sprockets? I counted the ones at the top and got 45 between the middle two, and then 24 between the two on the passenger side sprocket which is correct. I haven't checked yet but I was wondering if it was possible for the number of teeth between the crank sprocket and the first exhaust sprocket on the driver's side to be off but not the other ones?
