i think my piston rings r shot
nothinbutnissan
Car: nissan 240sx
wuz up guys i have a 92 nissan 240 and the guy i bought it from sprayed the motor now i think the piston rings r gone bcuz it smokes dis whitish smoke and i want 2 kno if that is the problem does it cost alot 2 fix or should i put another ka in it bcuz i was plannin on boostin this one but now i think that mite not be a good idea
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
do a compression test, then add oil to cylinders and do it again... normal procedure
typically white smoke is coolant burning, so u might have a blown headgasket, or even some intake manifold issues if the motor was sprayed.
id start with a compression check to try to better asses the damage.
nothinbutnissan
Car: nissan 240sx
yea ill c wuzzp im probly just gonna buy a rebuild kit
