i need some help getting more drop out of my hardbody
iDiiaBoLicaL
Car: nissan hardbody
my hardbody is lowered 3'' on blocks and the end of my leaf springs are tore to s*** and scratched up and someone told me the other day i could do something and i could get more drop and fix the leaf spring problem anybody no how??
Drift21_Hardslider
Getting the leafs re-arched is all I can think of. I think you can get a 2" drop from doing that.
Xtream Friction
Car: s2000 with a nissan skyline GTR
how low do you want to go
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You could let the air out of the tires
gtpboy00
Car: 94 Hardbody
there are several things you can do to get the truck down. I just picked up some 3" drop spindles for the front amd 3 " lowered leaf packs from Stillen. All parts are Bell-tech. THe front spring hangars can be cut even with the lower part of the frame and redrilling a hole to move the laef pack closer to the frame. that mod is good for about 1.5" of drop. I recommend you get the rear frame notched for clearance otherwise you'll smack the axle to the frame over large bumps. I also picked up a full set of Nitro Drop @ shocks as well. This along with a set of 18" Titan 5 spokes should be nice. If you want to go lower you're talking major frame work.
