float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Aug 25, 2005 7:04 pm
#1- That appears to have been wired for an SR ignitor. You've got the plugs for the CA/Q45 ignitor, I would re-wire it to use that ignitor, as it's much cheaper and easier to come by.
#2-That is the Knock sensor. I would assum that since you're using the USDM lower harness and you don't have this plug, it was a SOHC vehicle. You'll have to either get ahold of a CA lower harness, or get a DE on, or at least that plug from a DE one. I was lucky enough to get a CA lower harness, so I didn't have to mess with it. The problem with trying to adapt the KA lower harness to the CA is that the connections to the alterntor &/ starter are different and will have to be modified.
#3-Once again, problems associated with using the USDM lower harness. There will be plugs that you won't have places for and you will have problems hooking up the alternator &/ the starter. You will need to remove the speed sensor (one bolt, last sensor in transmission) from the USDM transmission, and put it in the CA transmission.
