NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Aug 10, 2004 1:38 pm
there are screws hidden behind the window control switch there is a screw in the bottom of the pull handle right behind the switchs. once you remove that screw the switch panel pops out. around the door release is a bezel if you use a pocket screw driver and gently pry up the bezel along the release lever ,only pry it slightly while working toward the front of the release lever pocket till it pops off, Be very carful with it as it breaks easily. there may be a couple other screws on the door panel maybe under the elbow rest. and possibly under some round caps obviously on the surface of the panel you just pop those caps open and there is a phillips screw under it. then the door panel is poped off, it has snap retainers holding it to the metal portion of the door.
