float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Aug 26, 2008 6:00 pm
LOL @ Gabby. That's good stuff.
You almost need to get it to the point where it's a repeatable problem. Something that you can get to fail at will. That will allow you to start narrowing things down. Until then, it's probably going to be a pain to figure out.
If it doesn't ever seem to get worse, and it just stays random and doesn't change, it's probably not an ignition problem. I know I sound like a broken record, but double and triple check all of your grounds. Go get some big 4 or 2 gauge wire from the hardware store and add grounds. If it's an electrical problem, it will only get worse if you leave it alone.
If it's a vac problem, then it will probably stay constant and may be harder to find.
