Pescakl1 wrote:
Philip, I have a scangauge, but i am not sure you can clear the self learning fuel mixture values with it.
You can clear faults when they appear, like a Check Engine Soon warning light, but these values are not values indicating any problem in the car, so I am not sure you can even access them with this tool.
Zengshengliu, if you already bought it, don't worry, it is a good investment: It helps a lot improving your way of driving more fuel efficiently.
For the resetting, why don't you go to the dealer like I said? They have all the tools and knowledge to do it for you, and since it is a 5 minutes job for them, it won't cost much (maybe they can do it while you are there for something else, like a oil change).
I just went to the dealer and they said they will not mess with it, so what am I suppose to do now? Will the scangauge II do the job? or I have to disconnect the battery?
