yeah i know, i've done it, it sucks.articzap wrote:If you have a spare set, I'd give it a shot. Check the resistor pack also.
A word of advice, you can change injectors without removing the intake manifold. Takes about 2 hours doing it that way.
checked it, its fine.float_6969 wrote:Timing belt jumped...
nope, stock 5 speed.greensx wrote:Any chance did you do a 5speed conversion? If so check you clutch neutral safety switch(if thats what you call it, basically the wires that connect to the auto shifter) in the cabin. Mine was giving me hell but once i plugged those up my car started turning on like normal.
2hrs?!? 40 mins tops for R and Rarticzap wrote:If you have a spare set, I'd give it a shot. Check the resistor pack also.
