I have the weirdest CA's ever!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Check your fuel pressure. Kthx.
boost_boy
Just because it exhibits spark and fuel doesn't mean it's supposed to run if other issues are hampering it. Spray starting fluid into a vaccum line leading into the intake or any hole that will get the fluid into the runners and then try and start it. If it cranks and runs for a second, you're either having fueling issues such as your fuel lines being crossed, etc, etc. If your ignition is weak (ie weak battery), the CA will not crank. And lastly, if the orange near the glove compartment is not connected or it's powered source is dead, it will not crank. Try those things and see how it goes.
Dee
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
fuel pressure is at 37
what orange? you mean the dash plug?
meminto
Car: S13 Silvia CA18DECT
Hrrrmm... you need pages ef-ec 39-42 of the workshop manual...
However if you already have it, it may be the euro version.. ignore base timing in this (if you have jdm ca18) as the jdm base timing is 10 +- 2
mbmbmb23
Ecu not plugged in all the way? Do you have an SAFC wired in? Have you tested your coil packs? My guess is timing.
eds13
yes ecu is plugged in all the way. no i dont and yes. i'm getting spark to all 4 cylinders.
articzap
Car: 2014 F150 FX4
Have you tried swapping the injectors yet?
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
If you have another CAS laying around try swapping it out.
eds13
not yet lol. i have no good ignitor right now.
and yeah, i tried that.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Did you try the fuel lines yet?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
eds13 wrote:not yet lol. i have no good ignitor right now.
When you swapped the CAS, how did you time it? If it is 180 degrees off you will get perfect spark, and no ECU codes, but the car will refuse to start, all it will do is crank and pop, if the starting fluid has no effect, I would pull the valve cover and manually retime the CAS.
PS, good to have you back Ed, even if only out of desperation. What car is this CA in?
eds13
you cant set the CAS 180 off....
sorry, kinda forgot about this thread.
if anyone wants a CA swap that doesnt run, call me.540-420-8346
will trade for a running ka24de+cash
karism
Car: 1992 Nissan 200sx. CA18DET
Are you postive that the ignition timing is set correctly??
I had a similar problem with mine when i bought it.It wouldnt fire,and only pop every 30sec of cranking.
It turned out that the CAS drive in the exhaust cam was broken.It was firing ,but the ignition timing was erratic,and at the wrong time
Spend some time making sure it fires all the time,and at the correct time.
Karis
