Buddyworm »
https://forums.nicoclub.com/buddyworm-u53933.html
Mon Sep 22, 2008 7:33 pm
Now that I've got my fancy turbo setup all together I think there's finally a point in doing a build thread. I suppose I should start from the beginning.
I started out with this:
Which I crashed.
So I put a CA in it.
But it was a ****ty engine so I sold it, kept the good bits, scrapped the old chassis and bought a Silvia with a leaky headgasket. Fixed it. Three times. First to fix the original leak. Second after my wastegate vac line breaking on my first test drive, overboosting the turbo and blowing the newly installed gasket. And third after the ARP studs loosened up. Needless to say I learned my lesson, had the head resurfaced, retorqued the ARP's after 100km and began drifting it.
Put some HKS 256 cams in.
Then I put a front-mount on it.
Followed shortly after by oldschool Greddy flavor!
Currently running a hella conservative tune at 0.8bar, which I shall be remedying tomorrow. So far I can say this: If you have a chance of picking up one of these manifolds, DO IT. F!@# that equal length stuff, I love the sound it makes. With the cams and the equal length stainless manifold that came on it it had the slightest hint of a lope at idle, now the engine burbles.
Mods, for those who like lists:MotorGreddy LS core, autobahn88 pipingHKS 256* in/ex camsARP HeadstudsTrust Octopus TD05/6 bottom mount maniMHI TD05-14bTrust Type-S external gateECR33 MAFFET CoilpacksNIStune
The RestTein FlexCheap motegisTomei T-TraxEbay exhaust
Modified by Buddyworm at 10:57 PM 9/22/2008
