fixer wrote:YOU TOOK OUT THE DETENT SPRING FOR ONE OF THE SHIFT RODS, the drain plug for your trans in facing the passenger side on the bottom of trans. you will need to find the ball bearing and replace the ball and spring into that hole. it is shifting easier because there is no detent on one of the shafts. trans may pop out of gear during hard accelleration.
Holy Carp....Thanks for the info fixer. I'm glad I took photos because I wasn't 100% sure that I removed the correct drain plug, it simply looked like the lowest point other than the plug where the neutral/reverse switch? is . I'll look for the correct plug on the passenger side of the trans.
I saved the old drained fluid in a 1 gallon can so I'll run it trough a strainer to see if the ball is in there.
BTW when putting the spring and ball back in does the spring go in first or the ball?
