WELL...... now that seems to be a logical solution to diagnosing.... I should have thought of that.dattodude wrote:That's the sound of 'baby jesus' crying...
or a tight timing belt.
I'd agree with the waterpump theory, and suggest to remove the waterpump belt for 2 minutes next time the engine is at home, and cold. If the noise still happens...it ain't the waterpump.
I checked it out when I dumped the oil a 2 nights ago....... no metal shavings..... Im always worried for any signs of wearchefneiman wrote:Sounds like the the timing belt tensioner.
For the future, you should consider getting a magnetic oil drain plug off ebay for about $15.
If you're ever concerned about your bearings, just drain your oil and check for inconsistencies in friction shavings.
Good Luck !
-Mikhail
well since i had my Alternator rebuilt a year and 1/2 ago...... I would think it is the other one.float_6969 wrote:That sounds like a bearing noise to me. Either the alternator or the water pump would be my first guess.
Pull the belt off and see if it sound disappears. You can run the car for a couple min w/o the pump or the alty running w/o any problems.
lucky...my pump went out after like 6 months of owning, but then again i ran it in 3 track days lolca18detgabby wrote:update: thats what I get for letting it run.........
was disassembling the IC piping so that I could access the belt, I looked underneath the car and find a pool of water...... the good news is I caught it early, the bad news is that i have to drive my BFs mz6 for a few days well I wait for a WP.
Ps nearly 2 years w.o an issue...... O well, it is fun to think that the water pump that is dying right now, is the same water pump my CA came with from the factory. I guess it was bound to die eventually. 20 years for a water pump...... thats nissan engineering for ya
LOL I layed in my bed and read the whole thing last night..........DALAZ_68 wrote:
well now u can use my walkthru to replace ur pump, and u might aswell change ur belt like i did, specially since it got hit by water
bought a brand new WP at advance(last one I could get ahold of w/o waiting till after xmas..... and I need to get around) with lifetime warranty for 34.99 complete with gasket.r34 gtr wrote:Buy an OEM et water pump. The warranty on the factory part comes in handy sometimes.
it was surprisingly cheap as u found out...and the lifetime waranty is the ISH mangca18detgabby wrote:
ordering a WP (is the FR motorsports one any better or worse than the genuine nissan ), Greddy Timing belt(actually been oddly eager to do this ), and new thermostat to night. should be about 250 shipped to my door when all is said and done. hopefully it is here before Xmas.
PS the re-maned from autozone or advance...... what did that cost you? was there a core charge?
