LA02MAX »
https://forums.nicoclub.com/la02max-u47165.html
Tue Nov 21, 2006 7:16 pm
Is your car a 2000 or 2001? If it's a 2000, then someone replaced the coils on your car before, because like maxhopper said, the ones ending in 0 and 5 are the older (supposedly weaker..) coild while the new 'updated' ones end in 1 and 6.
However, if your new coils are, in fact, new you shouldn't be having problems. Have you taken it back to the infiniti dealer? Was it having problems when you left the dealer? There aren't too many things that can go wrong when replacing the coils on a DE-K (unless your dealer is retarded and removed the upper IM) so either your parts are defective, or it's just a coincidence and something else went wrong.
Having bad coils for a while will not do any permanent damage to your car, but like I mentioned before, it could be something else. I suggest checking to see if everything is attached correctly (unplugging a coil gives causes your car to run rough/stumble) and then go from there. Take it back to whoever installed it if you cant figure it out yourself
