d240t2 »
https://forums.nicoclub.com/d240t2-u5383.html
Mon Nov 03, 2003 12:59 pm
I don't think he said it backwards. He just didn't specify which line he moved. I think he moved the signal line for the actuator from the hot pipe to the cold pipe, but kept the signal to the gauge in the intake manifold (so it still reads vacuum). As such, now the wastegate is opening later to compensate for the pressure drop across the intercooler.
In other words, the wastegate wants to open at 7psi. Before, with the signal line on the turbo outlet, the actuator opened at 7psi, there was 2psi pressure drop across piping, intercooler, and throttle body and so the gauge read 5psi. Now, the signal for the wastegate is after that...so the turbo puts out ~9psi, there is a ~2psi drop through all that stuff, and now the gauge reads 7psi (as does the actuator).
