shadydolo »
https://forums.nicoclub.com/shadydolo-u11714.html
Mon Mar 01, 2004 5:30 pm
Hey everyone, 92Q owner here with small problem getting my Q to stay on. The AC idler pulley was contaminated and was not free to spin causing restrictions throughout all the belts coming from the crank shaft. As an experiment, I removed that idler pulley and belt and drove it like that for a day. My car started up clean with no problem with obviously less restriction (for those looking for a little more power sacrificing but their AC.) I replaced the idler pully and it had no problem but went back to starting and cutting off. I would have to hold down gas and some smoke (black, carbon build up?) woudl shoot out and then the car would be able to idle on its own. The car has about 147,000miles on it, last injector cleaning at about 80-90K miles. Would you think this would be the main problem or could it be a potential failing injector(s), or possibly failing fuel pump. (Fuel filter has been changed recently). One more thing, where can I find a repair manual for the 92 Q without being raped on cost?
