Spacers are dangerous...they change the handling of the car by putting the wheels out farther from the suspension. As far as Z rated tires...good luck in snow.500dolla wrote:Hey guys im sorry to be posting this but i havn't found a good mazda site yet and this forum was so helpful to me with my G20, and i thought this would be common knowledge on cars.
SOI have 18" wheels on my Mazda 626 with 225/40tires , there is some rub against the strut guard or w/e that roundish plate is that holds the bottom of the spring. Would spacers do the trick or am i talking about a smaller strut( giving more width clearing)?
Honestly its not worth having rims these big, too expensive for tires. I bought the car with it and it has Z rated tires. Z rated with 130hp brilliant. I might sell the car with the rims and go for my original thought. A 240!!!!
if you are not using a spacer the hub will be in the same relation to the wheel hub reguardless of the offset, even though the outside edge might be pushed out futher. the difference between using a small spacer is negligible, less that 7mm or 1/4in.gotak wrote:Doesn't pushing your wheels out does create more load on your bearings as now you have a longer lever in the form of the wheels being out further?
or you can go with your original thought and sell the mazda for a 240, or a sentra! what kind of wheels are they?500dolla wrote:Thanks all for your input, i did get the spacers, they work good but im just going to get 4 steel wheels for the time being, i didn't know custom wheels would be this much of a *****. I can either sell for a pretty penny(around 1000 total) or keep for my next car(hopefully can handle the rims)
