How Works/dashboard headlight height adj. switch QX4?
neagan
Car: 2002 Q45 * 2001 QX4* 2008 G37* 1988 IROC* 1941 Dodge Army Trux* Racecars
I have that 'rolling' switch to the left of the steering wheel, next to the power mirror adjustment switch,that is supposed to adjust the headlights up or down in case the vehicle is loaded down (or so I'm assuming). Nothing seems to happen when I move it. Is it normally visible when you move it to any of the 3 settings? (2001 QX4)
Is it run off a fuse? Nitro
Jack1944
You should be able to see it move...I can see my '01's move...Shine it up against a wall, you can watch it move...Or should be able...
neagan
Mine are definitely not moving. Anyone ever had this problem?
ricehead
Car: 2002 Infinity QX4
the motors burn out, or the fuse/relay blows... check the latter first, or you'll have to pay big big bucks for the former
neagan
Yep, I started searching for where the fuse/relay is for that puppy. Any ideas? Also, I just found out that there's a fuse box behind the glovebox? How do we get the glovebox out of there to access? I also believe that the cabin air filter is stashed near there. Nitro
