SleepyHB wrote:hey 94_240sx, I just recently upgraded to z32 30mm brakes, I'm running z32 MC with my stock fluid container and the car was auto so I'm running auto brake booster, anyway the brake feels squishy, I've already bleed it about 5 times... any idea?
Let me ask you some questions.
- What brake lines are you using? - Did you bleed in correct order and use a clear tube? If you don't use clear tube, air will get in. Driver's rear->Passenger rear->Passenger->Driver- Are bleeders on top of calipers?- What kind of brake fluid are you using?- Any leak under the BMC especially where MBC meets booster?- Did you make sure 3rd fitting is there on BMC?- Are you using correct rotors for 30mm calipers?
