How to tell if ignitor is bad??
Q45dude
Car: 94 Q45
94 Q45.did a search but can't find any in relates to how one can tell if your ignitor is bad?Can anyone tell me how to check? Can i Ohm it like the injectors/KSs??
thanks
Q45dude
Car: 94 Q45
WOW!!!!!!!!All these Mods and experts and assuming no one knows the answer........................
1990Q45'r
Car: 1990 Q45
Yes, you can use your ohm meter to check them out. Info in FSM
Q45tech
Q45 ignitor failure is so rare that trouble shooting is almost never considered. THe usual problem is an untrained mechanic or owner swaping the connections or shorting during testing. The Darlington transistors inside for each coil are very robust.
Make sure the IC inside ecu is providing the proper voltage for ignitor and the IC has not itself failed.
Since all coils are provided a common +12 [just as injectors are] some times a bad connection for a bank will deenergize groups of 4.
captainluigi
Car: 1996 q45t
Dennis, you continually amaze.
