How to remove oil pan on a 91 hardbody 2WD? Please help!
myidea7
OK... so I have the timing chain problem, I pulled the front timing cover off and have the pan loose, but can't get it out. What is the fastest way to get this out or is there a way to do it besides raising the engine? Can the suspension part that runs under the pan be removed? Thanks any advice is appreciated.
s13_240_rb20
Car: 1990 240sx RB20DET
My truck had this bar already removed and the oil pan off when I bought it and the wheels still stay on...so I think, ya, it can be removed. but I don't know about the other 2 (that are probably the ones you think are in your way).
--TJ
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The only way to remove it is to remove the bar that runs under it.
myidea7
OK thats what I needed to know, thanks for the info guys. I thought that if I removed that bar I would have to put the truck on jackstands as the suspension wouldn't hold up anymore once removed.... or something to that effect, but I guess from your pic this is perfectly safe? Thanks
Rev_D21
You'll just need an alignment drift to get the bolt holes to line up for installation.
