Niti QX4 »
https://forums.nicoclub.com/niti-qx4-u273552.html
Sun Mar 13, 2022 9:08 am
So what is the thread size of the retaining bolt for the passenger side wheel speed sensor?
The bolt holding in the wheel speed sensor was seized (1999 QX4) and broke off during removal. Then when I attempted removal of the wheel speed sensor, it was stuck. Had to order a new sensor, but I had no way to get out the remains of the stuck bolt.
I used penetrate, heat, and then welded a nut to the remains. Nothing worked.
So I drilled it out and now I'm left with pieces of the old bolt still stuck in the threads. I want to use a tap to clean the hole out, but I want to make sure I use the right tap for this.
Any ideas?
Old, also if anyone knows the thread size of the Phillips head screws (and length) that hold in the dust shield I need that too. Had to chisel those four screws off to remove the dust shield so I could get to the wheel speed sensor bolt hole better.
