CoupeVQ35CVT »
https://forums.nicoclub.com/coupevq35cvt-u137499.html
Mon Jul 20, 2009 7:39 pm
I was installing a WAI in my Sentra last year, and accidently started up the car not realizing I had the MAF removed from the air pathway.... the car started up then sputtered and turned off, and threw some MAF error code, obviously.
I plugged it back in and cleared the code, and it worked normally. So if I'm to assume the Altima ECU is similar in behavior, then no if the filter itself falls out, it will not know anything's wrong, until something hits and destroys the MAF sensor, OR the maf adapter and whole section fall off and air no longer runs through it, in which case the engine will or should turn off. Lots of fun if it happens on the highway when you're merging I imagine.
