GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Wed Jul 30, 2008 3:06 pm
Free of charge of course...
Automotive Recall and Technical Service Bulletin Titles for 1993 Infiniti J30 V6-181 3.0L.
TSB Number & Issue Date TSB Title96-031 JUL 96 Recall - Seat Belt Pre-Tensioner Replacement92062 NOV 92 New Law Concerning Correction of Safety Campaign96-028 JUN 96 Recall - SRS Label Replacement92021 APR 92 Recall - Seat Recliner Button Becomes Mispositioned99-037K OCT 07 Electrical - Battery Testing Equipment/Procedures00-024E AUG 07 Brakes - Judder/Noise/Pedal Feel Diagnostics/Repair99-043B DEC 06 Paint - Swelling/Discoloration Under Paint Guard Film99-014C NOV 06 Vehicle - Flat Towing Guidelines/Precautions06-022 NOV 06 Wheels - Chrome Wheel Handling When Mounting Tires99-036C MAR 06 Starting/Charging System - Test Procedures/Tester05-008 FEB 05 Interior - Rubber Floormat Installation Precaution01-077A OCT 04 Paint - Removal Of Enviornmental Iron Particles01-033A OCT 04 Restraints - Seat Belts Slow to Retract04-038 AUG 04 Brakes - On-Car Brake Rotor Resurfacing03-062A MAR 04 Engine/Transmission - Precautions During Replacement00-042A NOV 02 A/T - Oil Cooler Cleaning Procedure02-007A MAR 02 Engine Coolant - Refill Procedure and Tool01-048 AUG 01 Child Seat - Top Tether Strap Anchor Installation01-003 FEB 01 Seat Belt - Slow Retraction00-027 APR 00 Steering - Pull Diagnosis & Repair00-016 MAR 00 Consult-II - NATS Software Update00-017 MAR 00 Consult-II - Software Cards Updated00-020 MAR 00 Essential Tool Shipment Summary00-019 MAR 00 ACR4 Refrigerant Machine - Maintenance00-009 FEB 00 Brakes - Steering Wheel Vibration/Pedal Pulsation00-002 DEC 99 Sunroof Rail Assembly Repair99-035 JUL 99 Y2K Compliance - Asist And Consult Tools99-032 JUN 99 ABS System - On-Car Brake Lathe Precautions99-012A MAY 99 A/C System - Refrigerant Leak Detection Tool99-013 APR 99 Speakers - Popping or Crackling Noise99-001 FEB 99 Strut - Replacement Guidelines98-065 JAN 99 Vehicle - Squeak and Rattle Materials Information98-059 JAN 99 A/C System - Receiver Dryer Replacement Guidelines98-048 NOV 98 Oxygen Sensor - Service Information98-027 JUL 98 Sealant Application - On Corrosion Related Repairs98-029 JUL 98 Special Tool - A/C Leak Detector98-025 JUL 98 Instrument Panel - Inspection After Air Bag Deployment98-017 APR 98 Windshield Wiper Blade - Refill Installation97-041A MAR 98 Engine - Cranks, No Start/Hard Start98-003 JAN 98 A/C Connection O-Rings - Information97-034 AUG 97 Bumper - Refinishing Techniques97-016 FEB 97 Air Bag Harness - Replacement97-011 FEB 97 Wheels - Balance Machine Adapter Kits96-048 NOV 96 ECCS - Testing Precautions96-046 OCT 96 Fan To Water Pump Flange - Installation Procedure96-043 OCT 96 Power Antenna - Replacement Sleeve96-041 SEP 96 A/C System -Refrigerant Leak Detection Procedure96-040 SEP 96 C/D Autochanger - Stuck Magazine Removal96-030 JUL 96 Suspension - Vibration Above 40Mph96-050 JUL 96 CONSULT - Exchange Programs96-025 MAY 96 A/C System - Evaporator Leaking96-018 APR 96 Engine - Cranks, But Will Not Start (Hard Starting)96-015 APR 96 A/C System - Retrofit Procedures96-010 FEB 96 Radio - Weak or Noisy FM Reception96-005 JAN 96 A/C System - Hot & Humid Air on Auto A/C96-007 JAN 96 A/C System - PAG Oil/Refrigerant Quantity ChartATRATB342 JAN 96 A/T - High or Low Line Pressure95017A DEC 95 Seat Belt - Damages Door Finisher Panel95072 DEC 95 Door Finisher - Premature Wear95062 OCT 95 A/C System - PAG Lubricant95054 OCT 95 CONSULT - Program Loading/Initialization95057 SEP 95 Distributor - Reman Program95056 SEP 95 Starter/Alternator - Reman Program95051 SEP 95 Keyless Entry Remote - Battery Replacement95043 SEP 95 Rear Brakes - Squeak/Squeal Noises95046 SEP 95 Windshield - Damage Responsibility95035 AUG 95 Speakers - Remanufactured Exchange Units95041 JUL 95 A/C System - Refrigerant/PAG Oil Capacities95042 JUL 95 A/C/Fuel Pump Relay - Diagnosis Precautions95033 JUN 95 A/C Compressor - Leak/Noise Diagnosis95034 JUN 95 ECCS System - Testing Precautions95023 MAY 95 Door Lock - Intermittent Self Locking95012A APR 95 Loose B Pillar - Lower Finisher Repair Procedure95019 APR 95 Tires - Snow Tire Recommendations95020 APR 95 DTC 45 - Diagnosis Procedures95021 APR 95 Enhanced Emissions Program - I/M24095008A APR 95 Front Seat - Rattle Noise95015 MAR 95 Paint - Waterborne Refinshes95005 MAR 95 A/C - Proper Parts Installation Procedure95004 MAR 95 A/T - Procedure for Detection of Leaks95009 FEB 95 Essential Tools - New Release95003 FEB 95 A/T - Remanufactured Program95006 FEB 95 Catalog -Tech Mate Special Service Tools93062A JAN 95 Throttle Body - Erratic Operation/Chamber DepositsATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque SpecificationsATRATB297 JAN 95 A/T - Pressure Control Solenoid Replacement94014A DEC 94 Power Antenna Rod Replacement94049 NOV 94 MSDS Information For Body Parts94048 NOV 94 Oil Dipstick And Oil Pan Caution94062 NOV 94 Recommended Fluids/Lubricants/Chemicals94060 NOV 94 Steering Wheel - Shimmy and Vibration94052 OCT 94 Pearlescent Paint Refinishing94057 OCT 94 Idle Speed - Fluctuates When Engine Is Cold94058 OCT 94 Rear Parcel Shelf - Alignment94056 OCT 94 Trunk Lid Actuator - Replacement94054 SEP 94 Service Procedures For Retrofitted A/C Systems94047 AUG 94 Engine Control Module - Identification94046 AUG 94 Engine - Knocking Noise At Idle94040 JUN 94 A/C - Oil Recomendations93061A JUN 94 ABS Warning Indicator - Abnormal Operation94043 JUN 94 Key Reminder Switch - Improper Operation94038 JUN 94 A/C - ATC (False) Error Code 5294037 JUN 94 Clear Coated Finish Service94020A MAY 94 A/C - Temperature Fluctuation94034 APR 94 Ignition Switch - Key Sticks/Accessory Power Loss94031 APR 94 Door - Welt Rubber Torn94029 APR 94 Front Seat Belt Extenders - Available94033 APR 94 Battery Charging/Replacement Data Sheet94012 MAR 94 Brake System Diagnoses Amendment To Service Manuals94025 MAR 94 Loading & Initializing Consult UE940 Program Card94023 MAR 94 A/T - Torque Converter Lock-Up Shock94022 MAR 94 A/T - Fluid Cooler Service Procedures94015 FEB 94 Keyless Entry Battery Replacement94011 FEB 94 Recommended Oil for RWD Differentials94011 FEB 94 Loading/Initialization of CONSULT Program Cards94010 FEB 94 Paint Contamination Identification And Repair94000 FEB 94 Rough Idle (Platinum Spark Plug Cleaning Procedure)94007 JAN 94 Brake - Judder/Steering Wheel Shimmy94001 JAN 94 Roof - Creaking NoiseATRATB258A JAN 94 A/T - RL4R01A Soft Shifts, Slips Under Heavy Throttle93069 DEC 93 Starter Hold Relay Circuit93068 DEC 93 Remote Transmitter Programming93067 DEC 93 Green or Blue (Type 1M) Relay Caution93064 DEC 93 Ignition Timing - Adapter Service Tool93062 NOV 93 Throttle - Chamber Deposits93060 NOV 93 ATC - Recirculation Timer Logic93059 NOV 93 Clock - Illumination Dim At Night93058 NOV 93 Aftermarket Metallic Window Tints On Rear Glass93055 NOV 93 Cellular Telephone - Interference93056 OCT 93 Service Manual - Fuel System Correction93024C OCT 93 New Clear Coat Paint FinishATRATB191 OCT 93 A/T - Failsafe Modes93049 SEP 93 CONSULT General Information93048A SEP 93 Battery - Maintenance & Storage93045 SEP 93 Vehicle Paint Maintenance/Storage Recommendations93050 SEP 93 Cross Linking Clear Coat93047 SEP 93 CD/Cassette/Radio - Error Message Description93046 SEP 93 Paint Guard Film Removal With New Clear Coat93-124 SEP 93 Loading/Initialization Of Consult Program Cards93044 AUG 93 A/T - Overhaul Sun Gear Parts Supercession93042 JUL 93 Rear Brake - Judder93038 JUN 93 Water Leaks Trouble Diagnosis93036 JUN 93 A/C - Kent-Moore ACR4 Machine Usage Information93030 MAY 93 Battery Replacement Guidelines93032 MAY 93 CD Player Faults - Diagnosis93025 APR 93 ECM - IdentificationATRATB164 APR 93 A/T - RE4R01A, R4A-EL Premature Planetary Failure93018 MAR 93 Driver Side Air Bag Cover - Replacement Procedure93012 MAR 93 Side Seat Finisher - Improved93015 MAR 93 Seat Belt - Tensioners Self Diagnosis93014 MAR 93 Headlamp - Adjustments for Aiming Section93011 FEB 93 A/T - Excessive Shift Shock93005 FEB 93 Rear Seat Back Rattle93004 FEB 93 Inner Fender Panel - Rattle93003 JAN 93 Cassette Tape Player - Maintenance Information92069 DEC 92 Alloy Wheels - Precautions On Aftermarket Chroming92065 DEC 92 Seat Belt - Extenders Part Applications92066 DEC 92 Service Manual - Amendments92064 DEC 92 Poly Groove Belt - Installation & Alignment92061 NOV 92 Maintenance RecommendationsATRATB144 NOV 92 A/T - RE4F01A Burnt High Clutches/2-4 Band92047 OCT 92 Air Bag System - Diagnosis After A Collision92045A SEP 92 A/C - Refrigerant Capacity (Revised)92050 SEP 92 Refinish Paint Formula Code NumbersATRATB132 SEP 92 A/T - Intermittent Electrical Problems92044 AUG 92 Door Lock - Remote Transmitter Programming92043 AUG 92 Ammco On-Car Brake Lathe Operating Guidelines92042 JUL 92 Cellular Phone - Noise/Interference/Dropped Calls92037 JUL 92 CD Player - Warning Concerning Aftermarket Installation92035 JUL 92 Cellular Telephone Antenna - New92024 APR 92 Polyurethane & Polypropylene Bumper Facia92013 JAN 92 A/C - System Changes to R134a Refrigerant91049 DEC 91 ABS - Clunk Noise/Pedal Pulsation
And a few others look interesting too.
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge91039 JUL 91 Motor Oil - Viscosity Recommendations91027 MAY 91 A/C - Recommended Compressor Oil91022 MAY 91 CONSULT Lithium Battery - Replacement91007 FEB 91 A/C - System Refrigerant OilATRATB028 OCT 90 A/T - Engine Vacuum TestingATRATB9002006 FEB 90 A/T - Choosing the Right ATFATRATB8930 OCT 89 A/T - Math Part IIATRATB8927 SEP 89 A/T - Twenty Steps To Successful RepairsATRATB8923 AUG 89 A/T - Math Formulas Part IATRATB8754 SEP 87 A/T - Front Bushing WearATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
