sideways24d »
https://forums.nicoclub.com/sideways24d-u64505.html
Thu Jan 31, 2008 11:40 am
you would have to take the distributer out and test it. The rotor needs to be spinning......Why are you testing this sensor? You do know you can flash the ecu and that would tell you if it's bad. flash it and see what codes you get. if you have an intermittent stall, w codes for ignition, transistor, and cas, your distributer is bad and needs replacement. CAS is a part of the distributer.
