how much to retard timing
rco8786
Ok, at a maximum of 10psi, 7psi daily...can i get away w/ using the distributor to retard the timing? if not, what would be the easiest way to do it and how much should i do it. I don't have the funds for a new ignition and all that good stuff. I will be running a T3 w/ safc, walbro, stock injectors(for a lil while).
I am Technoman
Car: ???
I would not boost on stock injectors!
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock injectors will be maxed at or before 4psi with only an AFC - It can add more fuel IF the injectors are not maxed, but once they are at 100% duty cycle, it can do no more...
Only way to make injectors flow more is fuel pressure...an RRFPR is a decent cheap choice, but I'd reccomend getting some 370s.
Those will get you to about 250rwhp, or ~9psi from a T3 (maybe 10psi for 250rwhp, but that may be pushing it).
Later - Brian
daniel240
Car: cars/motocross
im going to use stock injectors with walbro f/p and fmu. with a max boost of 6or 7psi. i think this should be ok. i also want to know about the timing. i was going to retard mine 1 deg. i want to know exactly how to adjust it to exactly 1 deg. with the distributer?
WDRacing
At 7 psi just retard the timing 1 degree. When money allows, purchase a boost dependant timing controller from MSD or similer. They're about $130 I think. I'd suggest a knock metter, but if you can't afford a timing box, you probably can't afford a knock metter.
WD
I am Technoman
Car: ???
If you use a FMU you may want to invest into a fire extinguisher! I say this because of how much fuel pressure the FMU builds in the fuel rail and lines.This will only cost about 40 bucks and I would have one because my car cost thousands and I really don’t think I could replace her.
rco8786
Ya the injectors are only a VERY temp thing...and really this whole set up is. 10 psi will be absolute max for a dyno run or something, so 370's should be fine for me. Thanks for your help guys.
fiznat
Car: Grown up :(
just make sure that your ECU (or whatever else you might be running) knows how to pulse your injectors correctly. You cant just change injectors and not worry about how they're controlled when you decide to upgrade.
daniel240
Car: cars/motocross
yea thats one reason i want to keep the stock injectors
I am Technoman
Car: ???
Humm the greddy e manage cost less than 300 dollars on ebay and 370's should only be around 100 dollars max! Oh and a new fuel pump is around 100 dollars so for about 500 bucks I can have a pretty damn sweet fuel setup that will take me to around 300HP at the flywheel humm ill go that route!:D
rco8786
fiznat wrote:just make sure that your ECU (or whatever else you might be running) knows how to pulse your injectors correctly. You cant just change injectors and not worry about how they're controlled when you decide to upgrade.
the safc will handle that won't it?
huguetpj
Car: 93 KAT Coupe
rco8786 wrote:the safc will handle that won't it?
yes
EastCoast240
Does the e-manage allow timing adjustment?
daniel240
Car: cars/motocross
how do you adjust the e-manage for the injectors?
I am Technoman
Car: ???
EastCoast240 wrote:Does the e-manage allow timing adjustment?
Yes, but you have to buy the timing harness and i think you can also buy a MAP sensor so the E manage can see boost but that will not allow you to remove the MAF. It just can see boost and move timing.
I am Technoman
Car: ???
daniel240 wrote:how do you adjust the e-manage for the injectors?
In the program that you run on your'e laptop or computer you can type in 370,440,720 get the point? And you can also tell it that you have a Z32 MAF!
I am Technoman
Car: ???
With a properly tuned E manage and fuel pump and a set of 440's you should have no problem boosting 12 PSI or maybe 14with good gas!;)
DriFt3r
Car: Racing and Drifting
How reliable is the emanage and is it worth the money?
DriFt3r
Do you guys think that its better then the jwt ecu? I rather spend $500 on the emanage if its better then to get a jwt.
I am Technoman
Car: ???
I know a few guys who run the e manage a love it! It really is a good fuel ECU for the money. BUT if your plans are to run 400HP or higher go the JWT or a stand alone I only want maybe 270 RWHP out of my car so the e manage is my choice. :D
DriFt3r
So if I am planning on more then 400 hp then the emanage wouldnt cut it? So its better to get the JWT then?
rco8786
DriFt3r wrote:So if I am planning on more then 400 hp then the emanage wouldnt cut it? So its better to get the JWT then?
The e-manage would technically work...but if you're spending that much $ on your motor anyway you're better off w/ the JWT.
SloS13
rco8786 wrote:Ya the injectors are only a VERY temp thing...and really this whole set up is. 10 psi will be absolute max for a dyno run or something, so 370's should be fine for me. Thanks for your help guys.
are you saying you're gonna run 10psi on stock injectors? or 370's. Im confused
huguetpj
Car: 93 KAT Coupe
rco8786 wrote:The e-manage would technically work...but if you're spending that much $ on your motor anyway you're better off w/ the JWT.
Why would he? With the e-manage he has tune-ability... and at 400HP I bet that comes in handy.
rco8786
SloS13 wrote:are you saying you're gonna run 10psi on stock injectors? or 370's. Im confused
No no no...I wouldn't touch 10 psi w/ stock injectors. They will be *hopefully* pushing 7 for about 2 months....but most likely I will end up just buying injectors b4 I turbo anyway.
rco8786
huguetpj wrote:Why would he? With the e-manage he has tune-ability... and at 400HP I bet that comes in handy.
Ya I guess that's true..
I am Technoman
Car: ???
I think a JWT ECU and a E manage piggy backing it, would be sweet! 7K rev limit no speed cut, base map is setup for turbo and you can tune the JWT ECU with the e manage on the dyno! This would cost about 1,200 for all the harnesses and stuff.
This is what you could do.Z32 MAF upgrade without sending it back to JWT.Upsize injectors up to 720's without sending it back to JWT.Control timing for more HPAdjust A/F mixtures for the most HP without sending it back to JWT.Use sub injectors and harness for alcohol injection "big boost"Use the data logger to analyze and record what the engine is doing.
I would also like to have a wideband o2 sensor.This setup would be good to well over 500HP!
huguetpj
Car: 93 KAT Coupe
But then why would I spend my money on the JWT ECU since I can do everything it does (except maybe for the rev limit) with the emanage? :confused:
I am Technoman
Car: ???
I would really like to go faster than 120MPH
s86d
Car: autocross, backroad racing, and working on 240's
WD do you have any links to those boost dependant timing controllers?? Thanx
