how much is a 1985 n/a with a blown engine going for
A home for 1983–1989 300ZX owners!
profotoiam2
i blew my freakin engine due to the person who owned it tried to cover up the knocking sound it was making with extra oil well that blew the seals and bam blew up everything else
so to make a long story short how much is this thing worth scrap its not woth crap so i was hoping some one on this forum would either buy it need parts or at least think of how much its worth since i cant seem to sell it locally also i need 10 posts to put up for classified
Thanks rob
Modified by profotoiam2 at 10:08 PM 8/22/2008
profotoiam2
ps
im in the process of buying a 72 240 z twin carbs
how much do these go for typically and does any one know how much it costs to switch to fuel injection or can i even switch to fuel
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the 85 n/a doesn't have any real desirable parts, just depends on the condition of the rest of the car, is it a builder or a parts car? As a parts car I wouldn't expect more than $2-300, as a builder maybe $4-500
As for the 240, Used su carbs can be had for about $150, $500-800 for tripples, and yes you can swap in fuel injection but unless you plan to turbo it I'd stick to carbs
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Junk yard or donate the car, the donation angle gives you a minimum of $500 tax write-off and you have nothing to worry about with the state.
But you know that you can get a re-fub Japanese motor for under a grand installed, if you wanted to keep the car not expensive to get a new engine.
evildky
06 Nissan 350Z GT
nad if the car is a good builder why not just add a vg30et?
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
Where you located? Where you live can give me a pretty good idea what condition the car is in. But if the body has no rust, I say you should try to save it. If I went to one of the LKQs in Tampa on a holiday and got the engine block, heads, and internals; that'd run me about $80. If you are pretty savvy with cars you could swap the jy motor in (assuming it's in running condition) for next to nothing and have a running car. My rule of thumb is that a non-running common car is worth at most $500. Any common running car is usually worth at least $500. The jy will probably give you $400 for it, and the donation will give you the $500 as BadQ45t said.
Choose.
Return to “300ZX (Z31) Forum”
