biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Thu Aug 04, 2005 4:36 pm
need to change the pistons to either stock DET or aftermarket (stock DE pistons can't handle boost as someone proved once before, forget who now)
you won't have piston oil squirters
you will want a RWD crank pully, or just run w/o PS or AC (I forget which is the outsidemost)
you'll need RWD mounts, but the FWD block will mount RWD with RWD mounts unlike SR blocks
of course you'll need RWD transmission sorted out, and you'll want RWD head or to take EGR off FWD head and plug the EGR port, and RWD manifolds and accessories, and other outside bits
but in the block itself, you just need to change the pistons to handle the boost, you'll be without the oil squirters but thats it for differences internally.
