How exactly do you make a "ghetto sim" for the second o2 sensor?
nismoinsc
Car: 2002 Nissan Sentra SE-R
ok, if someone would describe to me (high detail please) or point me in the right direction on where i can find out how to make a "ghetto sim" that will stop my SES light and get my engine running to perfection so i can move on upgrading the rest of my exhaust.
nametakennow
Car: '06 MINI Cooper S
Electronic ones put a resistor in the wiring. However, another common method is to use spark plug non-foulers.
What you will need for the "ghetto sim:"
Two spark plug non-foulers (part number 42002 at Autozone) 1/2in drill bit
1. Put one of the non-foulers in a vice and drill out the center with the ½� drill bit2. Screw the O2 sensor into the drilled out non-fouler3. Screw these into the other non-foulera. It should look like this: O2 sensor -->drilled non-fouler--> non-fouler4. Screw all this into the O2 bung5. Unplug your battery and wait a sec to reset everything and then reconnect the battery
nismoinsc
thank you. that helps immensly
