marleyfan »
https://forums.nicoclub.com/marleyfan-u48825.html
Fri May 16, 2008 4:04 pm
It's pretty easy actually. Just pull off the rubber boots and pull off the wire harness. Then push down on the wire clip that holds in the bulb. Reverse the process to re install the new bulbs. Be careful not to touch the bulb and get oils from you fingers on it. The hardest part is getting your hand in behind the battery on the drivers side. Shouldn't take more than about 10 min total.
I hope that it IS only the bulbs. It seems strange to me that both would go at the same time but I suppose it is possible.
