Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Tue Aug 25, 2009 11:14 am
Uh no, more like the S13 hatch looks like the Z31.
As for the front end swap, it's pretty easy. The headlight and fog light wiring needs to be modified, cut those sections of the wiring harness out of the donor car and use that. The headlight area on the chassis have thin sheetmetal sections towards the front that will rub the 87+ headlights. Some people say you have to cut them out, but you can take a hammer to it and move it forwards a bit and everything will clear fine.
Beyond that, unbolt the front end parts, install 87+ front end parts. And you will need the actual bumper from the 87 unless you want to cut and modify the 84-86 bumper.
