Q70sGuy »
https://forums.nicoclub.com/q70sguy-u312736.html
Fri Jan 09, 2026 8:18 am
I checked and My AFS q70 lights “dance” when I turn on the car and the headlights come on, but it’s only a quick side to side. If the leveller in the back isn’t stuck or broken, it should adjust up and down based on how much weight is in the back. If the motor is dead and stuck too low, that’s a bit surprising because why would it point down by default? If the motor isn’t dead and If your lights are pointed too low you can adjust that at the headlight. Check the FSM for the procedure. Not sure if the motor itself can be replaced.
For side to side, I don’t think you can manually adjust, so if the motor is dead I’d check the FSM to see if it says replace headlamp assembly or motor
