RaiderKID wrote:Well since you live in SD. I would say get with robert he and his shop can hook you up on a deal.
we're already on it!
Ricko, sorry I couldn't get back to you yesterday... anyway, you need about 1000 watts RMS going to these subs...
if you bought the dual 2 ohm subs, then you will most likely wire those down to a 2 ohm resistance load... in this case, you need an amp that can push ~ 1000 watts RMS at 2 ohms...
here are some good amps...
JL audio 1000/1... 1000 watts RMS @ 2 ohms
Rockford Fosgate T1500-1bd ... ~ 1100 watts RMS @ 2 ohms
Rockford Fosgate T10001-bd.. ~ 1100 watts RMS @ 2 ohms (this is the 2007 model, but just as good as the current model, its larger, but has built in fans for more efficient cooling)
sundown audio SAZ-1500D.. ~ 800watts RMS @ 2 ohms
these amps will run you between $370 and $600 dollars... sorry, but real power aint cheap!
