moses »
https://forums.nicoclub.com/moses-u612.html
Wed Jan 29, 2003 6:42 am
Thanks Aries,I tried double gaskets with some sealer between them and that seems to have done the trick. I may have messed up the original seal by tightening it before I tightened the bolts at the head. I think it might have tweaked it a bit.Also, a tip to others doing this install in the future: you can get the original header out without pulling the steering assembly, but be sure to remove the heat shields AND break off the little tabs that they were mounted to. I broke off three or four of them and was then able to jiggle it through by myself (though it would have been easier with someone guiding from below also).
