Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Thu Oct 23, 2003 5:05 am
I disagree on knife edging the crank, bull nosing yes, knife edging no. In my opinion it's just ridiculous overkill for a street motor and while it will allow it to spin up faster, there's a reason the little men in white coats made those counterweights so heavy. My understanding is that your counterweights should be twice as heavy as your piston/rod combination for maximum engine longevity (thats from a machinist). When you have a rotating assembly balanced, EVERYTHING should be included, that means pistons, rods, flywheel, pressure plate, flywheel bolts, pressure plate bolts, and the front pulley. If it's attached to that crank in any way it should be balanced both individually and as one whole unit.
