heyman421 »
https://forums.nicoclub.com/heyman421-u167116.html
Sun Mar 20, 2011 1:18 pm
Made a little bit of progress, and now i know why so many people just leave these horns broken.
First of all, i have only a passenger side horn, and it's completely shorted out. I jumped it to the battery, and it didn't make so much a honk as a series of scary pops and fizzles which left my 16ga jumper cable hot to the touch. Yikes.
Once the horn was disconnected, i can now manually short and trigger the relay, but the horn button (center plate on the wheel) is VERY finicky. It didn't work at all at first, and now after loosening and adjusting it i can finally get it to trigger maybe 20% of the time. It seems that it has to be pressed JUST so for it to work and make contact with the little spring.
Anyways, i wouldn't have made even the small amount of progress i did without the pictures, so thanks again!
