jbay13 »
https://forums.nicoclub.com/jbay13-u274454.html
Fri May 19, 2017 2:29 pm
I can usually get one beep out of the horn then nothing for 15-30 minutes or more. Also it sounds weak and squeaky. I can go under the hood and wiggle the fuse/relay black box, with all the relays and it and it will beep several beeps and then it will stop and I have to wiggle or tap it again. The box is a bit loose as I can wiggle it back and forth. I took out the relay and it looked fine but you really can't tell. Maybe loose wires? Any ideas?
