jltibbs wrote:welcome aboard bro. i couldn't find anything in the how to's on this but i think i've seen it there before. it's been over 2 yrs since i replaced mine. i think on factory ones you have to remove the bolt. if not you just have to pull out that retaining clip and pop them right off.
Thx for helping me figure this out! The struts in place now are factory struts and I just don't see how to release the strut from the ball. The new struts (ebay) want to use the existing bolts/ball. Do you know how the retaining clip is removed? Do I just try to pry it out with a screw driver? I tried to just "whack"the factory strut off of the ball with a hammer, but it didn't just pop off. So I should remove the old struts along with the bolts/studs and then work on my work bench to seperate them?
Thanks again for the advice!
