BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Wed May 18, 2022 2:39 pm
Yes it is the same port. You either need to find a 220v plug in your garage (dryer typically use if electric). If you don't have that then you have 2 choices but both will require a real electrican to perform. You can do an installation of a 220v port into your garage and then buy a charger that is designed to plug right into the plug or buy a charger that is setup to go directly into your electrical system. I have 2 chargers at my house one inside the garage and one outside. The inside one I bought was Clipper Creek cost pretty low and works great. The outside one is an old one Envirotech that Nisan recommended back in 2011. That one has much superior build quality. If you doing an outside install then I would go for a more rugged one, if not go for the mid-grade clipper creek. Also see your local power company some give rebates for the install but they are not very expensive anymore.
