ThriceRules »
https://forums.nicoclub.com/thricerules-u9953.html
Sun Nov 09, 2003 8:55 am
Hey, I just bought a HKS Super AFR, and need to know where to run the wires to the ECU. Wires: 12 volt ignition, 12 volt battery, ECu ground, pressure sensor(air flow sensor?) , RPM signal, speed sensor, and throttle position sensor. Any help would be appreciated. Thanks in advance.
