HKS Head Gasket
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
I was looking at my motor the other day and laid down to look at the exhaust ports(the manifold and turbo arent on) and noticed HKS is stamped in the gasket. I believe its 1.2mm. This must be kinda rare, cuz I havent seen one for the CA. Also, what would this make my effective compression?
I was thinking around 8.0-8.2:1 compression. MORE BOOST! I havent taken off the head but Im kinda curious what kind of internals are in it. It also has a HKS Intake Cam so........we'll see.
jt15833
Car: 95' 240SX
nice getting a motor and just finding goodies like that, whered you get it from?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
ummm 1.2mm is the stock headgasket size... You never want to alter the compression through the headgasket as it messes up the quench area in the combustion chamber.
teambuiltnissan
Car: nissan 2 dr
1.2mm should be around stock or somewhere 9ish compression with stock piston.
there is no way in world 8ihs compression.
HKS still makes gasket for CA . I juts bought one for my freind
c-rad
teambuiltnissan wrote:1.2mm should be around stock or somewhere 9ish compression with stock piston.
Stock compression is 8.5:1. Stock headgasket thickness is 1.2mm. Therefore the compression should still be 8.5:1.
sideways danny
Car: s13, CA18DET
c-rad wrote:ummm 1.2mm is the stock headgasket size... You never want to alter the compression through the headgasket as it messes up the quench area in the combustion chamber.
the quench area does nothing at stock anyway as the clearance is too big
Kouks
okay, well I thought it was 1 mm, but anyways, it was a rough estimate on how thick it was, but I guess I was right. I dont plan on rebuilding it yet, just gonna drop it in the car and see how it does. Ill post pics when I get the motor cleaned up and parts put on. Get the Ka out....
slownslurious
I would want to know what is inside that motor. probably stock but... who knows?
sil_eightyRPS13
Car: 1989 RB27 cefiro
stock head gasket is around 0.9mm....and is half paper/copper.....
and HKS, GReddy, NISMO make one for CA18det....
sideways danny
Car: s13, CA18DET
sil_eightyRPS13 wrote:stock head gasket is around 0.9mm....and is half paper/copper.....
sorry you're wrong. the standard gasket is 1.2mm
